Everything fine Injector pump in yes a/c in, power steering pump how come the bracket does not fit ???
Because the power steering pump adaptor the compressor went out to overhaul with is not the one it came back with
3 hours later when we finish fabricating a bracket and look at the tappet cover gasket and dammit Jim it has a slit in it just like the one in the valve cover gasket . Fel Pro blue silicone, both bought from different vendors at different times. Any one else had this problem?
Oh well, better now than after it is bolted in.
One step forward 3 steps back.
Off comes everything to replace the tappet cover gasket again.
The bracket picks up the tail end of the pump now.
