there is geometry involved.. your new allison shifter with a 'P' likely has multiple positions to set the cable and the amoutn the cable moves per notch on the shifter.. this is adjustable.. you need to adjust those plates and screws so it pushes / pulls as much cable per shift as your 545 shifter did.. sometimes the manufacturer publishes the positions for various transmissions..
and it may be you need to use a new cable.. in my case my 545 cable will not have the proper travel so I bought my new shifter with a new cable that has more travel..
I havent yet installed my 'P' shifter however i did get the plates and positions correct to match my genometry i just have to mount it up...
Thanks, ‘Kid -
I did buy a new cable to match the new shifter as I thought that might be my initial problem. I think they are close to the same, but needed a new one anyway.
If I may ask - how did you set the geometry? Did you use the old shifter as a guide? Use an instruction sheet? Get settings from manufacture? (no documentation came with mine…). Or did you just know…?
Thanks a lot! I’m optimistic I can make it work! Thanks!
