Thread Tools Search this Thread Display Modes
Lady Liberty
Rivetboy's Avatar
Rivetboy Rivetboy is offline
Registry
Vehicle Name Lady Liberty
Year 1991
Make Bluebird
Model T/C 2000
Length 28 feet
1991 Bluebird T/C 2000
Basic Info Clean and runs good leaks a quart of oil every 25 miles from bad tappet cover gasket
2/21 Bus is assembled runs and drives very well very smooth Tremendous brakes painted white All new exterior lighting in LED DOT SAE replacement headlights When the external electrical is finished I finally get to start on the inside
Exterior
Painted white with gloss black rub rails. Want to put Alcoas on it
Interior
Getting ready to start I wanted the vehicle pretty before even thinking about starting on the interior Wife will be involved in this so it will be twice as hard as bpulling the engine and transmission..
Customizations
1991 Bluebird T/C 2000 Customizations 1991 Bluebird T/C 2000 Customizations
Engine took down to a long block and cleaned
Replaced all gaskets
front and rear crankshaft seals
2 new rear transmission mounts
New front engine mount
oil cooler
fuel pump
injection pump return valve
fan
all filters (fuel, oil, transmission)
oil pump
alternator
a/c compressor
a/c idler assembly
serpentine belt
belt tensioner
0spho block
etching primer
Cummins beige
Professionally overhauled turbocharger
profesionally rebuilt air compressor
gates radiator hoses
gates heater hoses
new injector return lines
larry bs starter overhaul
new 4 inch stainless exhaust pipe from the turbo 3 inch downpipe to big ol honkin flowmaster then side exit behind the rear wheel passenger side
Renovations and Repairs
1991 Bluebird T/C 2000 Renovations and Repairs
removed engine replaced at 545 with a rebuilt unit.
6 new tires
new brakes all the way around 6 new brake hoses 2 new front brake drums,
serviced air dryer
Moved 60 gallon diesel tank to other side of bus (drivers side).
Installed Derale fan cooler under bus for transmission.
plumbed in stainless steel braided hose with a/n fittings convoluted tubing on all fuel braided, heater etc.lines.
Replaced fuel and return line with OEM hose relocated water fuel seperator.
replaced check valve in line
Moved shifter from left side of steering wheel to right side
4 new shock absorbers
New 200 amp Alternator
Tow Vehicle
Electric bicycles and who knows probably an old Jeep like a 2014 Willys Wheeler in white
Favorite Camping Destinations
Any where we have not been is always a favorite
