Journey with Confidence
RV GPS App
RV Trip Planner
RV LIFE Campground Reviews
RV Maintenance
Take a Speed Test
Free 7 Day Trial
Home
Forum
Photos
Registry
School Bus Conversion Resources
Skoolie General Forums
Skoolie Owners Registry
TBD :: 2008 Thomas Minotour
Google
Click Here to Login
Register
Registry
Registry
All Registries
Browse by Username
Browse Recently Added
Browse Recently Modified
Browse Most Commented
Browse Most Popular
Advanced Search
Help
FAQ
Members List
Calendar
Search
Today's Posts
Mark Forums Read
Log in
Search this Thread
TBD
AlphaHare
Registry
AlphaHare's Registry
TBD
AlphaHare
View Public Profile
Find all posts by AlphaHare
General Information
Vehicle Name
TBD
Year
2008
Make
Thomas
Model
Minotour
Registry Image
Basic Info
E450SD, 6.0L, 5 window, high floor, 14,050 GVWR
09-30-2023, 02:54 PM
2
Danjo
Join Date
: Sep 2018
Posts
: 2,725
Year
: 2007
Coachwork
: Thomas Built
Chassis
: Minotour
Engine
: Chevy Express 3500 6.6l
I have an 07. I may have insights for you
11-08-2023, 08:25 PM
3
AlphaHare
Join Date
: Sep 2023
Posts
: 6
Thanks- chasing down a wiring diagram from DTNAConnect. Curious what you found or did to remove all the non-essential wiring. Already removed about 10 pounds of former telematics cat5 going everywhere.
You may also like:
Goldenmate Lithium Battery Review: Boost Your RV P...
The Ultimate Coastal Experience: Ocean Walk RV Res...
How Much We Really Spend RVing Full-Time Each Mont...
Class A RV vs Class C: Which One Is Right For You?
Telltale Signs That Your RV Has Termites
South Carolina's Lakeside Retreat: Crooked Creek R...
Get The Best Spot: 6 Hacks For Perfect RV Reservat...
7 RV-Friendly State Parks In Arizona
1999 International/BB 3800
Struggle Bus :: 1997 Thomas Saf-T Liner
Search this Thread
Show Printable Version
Email this Page
Search this Thread
Advanced Search
Switch to Hybrid Mode
Switch to Threaded Mode
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
Trackbacks
are
Off
Pingbacks
are
Off
Refbacks
are
Off
Forum Rules
» Recent Threads
N175 Pinion Bearing
Duh question, High Beam switch...
Part number for a replacement LED...
My "Assigned" Bus
Battery gauge dropping
INTERMITTENT Bus won't start
Where to go for insulation?
Saying hello from the Bayou (with...
Using coolant lines with after-market...
Last Maintenance Before Full Timing
Vacuum pump replacement
do i really HAVE to remove all this...
What’s Your Heater?
Reviva reman engine
Foam board on outside of stairs
Add Dump Valve for Air Suspension
Cummins ISB6.7 Engine - Pros and Cons?
Led brake lights
Featured Campgrounds
Scenic RV Park
Asheville, North Carolina
Thousand Trails Lake Gaston
Littleton, North Carolina
Thousand Trails PA Dutch Country
Manheim, Pennsylvania
Thousand Trails Kenisee Lake
Jefferson, Ohio
Sun Outdoors Wells Beach
Wells Beach, Maine
RV Preventative Maintenance You Should Be Doing Re...
Visit Yosemite National Park
Cold Weather Safety Tips That Every RVer Should Kn...
Setting Your RV Water Heater to Electric Power: A ...
Powered by
vBadvanced
CMPS v3.2.3
04:51 AM
-- Skoolie
-- Mobile
Contact Us
School Bus Conversions
Archive
Community Rules
Terms of Service
Privacy
Accessibility
RVLife
Top
