On the outside it looks like a typical ambulance with nice wheels... just look a little closer!
Interior
Inside, the bench seat on the right side was raised up to make a desk. Two marine mounts were used to install office desk chairs. A 3500-watt Kicker Audio stereo system was integrated into the interior of the box and another 1500-watt system in the cab alone!! Over 5000-watts of stereo ROCK THIS BOX... and there are Wakeboard Tower speakers mounted to the rear doors so the party is always LOUD & CLEAR!!!
There is also an amplified WiFi system so I can reach cell towers miles away to have perfect signal at any large events!!
Customizations
Besides the obvious Weld Racing 20x10" front wheels and the 20x12" rear wheels... this Ambulance rides on custom Bilstein shocks, springs and swaybars. It also has MagTec deep sump transmission pan & differential finned cover. Inside the rear axle is a Detroit Locker Diff with 3.50:1 gears which is how this 7.3L diesel can push beyond 120mph for extended periods of time!
All of the lighting was sponsored by Whelen and upgraded to full LED.
The 7.3L engine was tuned with bigger injectors and high volume HPOP with regulated return fuel to the injectors.
The brakes were upgraded with slotted rotors and larger calipers to help bring this rolling fury to a stop when needed!
The 5Gstore sponsored all the WiFi system with a Cradlepoint Router which allows the binding of multiple Cellular Wilson Amplifiers to use different provider hotspots to create a "pipeline" to the internet!!
