For the exterior modifications, We plan to remove all reflectors, labels, and "bus" stuff on the outside. We plan at least at this point to paint the top white, of course, and the sides machine grey or Massey Ferguson grey and between the top black rail and the third black rail we will paint a black stripe. We are planning to remove the bottom and second black rails from the side. The major modification will be removing the back and adding a bi-fold ramp in the back to load and unload the bikes. The ramp will be 2 six foot panels that will bi-fold and when opened should be 12ft long. If my geometry is correct that should be at a good angle to ride the bikes up into the back of the bus.
Interior
For the interior, We are planning to strip out all of the "bus" features, The walls, ceiling, & floor. We will insulate everything and cover with wood T&G on the ceiling, wood window seals and trim. From the wheel wells in the back to the back will be covered in aluminum diamond plate. from there forward will be laminate.
Tow Vehicle
Towed in the back not behind - 2005 Honda Goldwing (I know just ride that one) also a 2003 Honda VTX.
