12V source indicating air parking brake (push-pull) engaged?
Bus is 2003 IC 3800 with air brakes.
Our stereo receiver requires a 12V signal from the parking brake switch to enable certain fuctionality (for example, you have to have the parking brake engaged to set up the rear-view camera's guide lines).
There's no pressure switch or any electrical connection to/from the push-pull valve itself.
The gauge panel, however, indicates the brake is engaged, so it's getting this signal from somewhere.
Does anyone know where? I don't know which of the countless wires connected to the guage panel is responsible for this signal, so I can't even track it back from there.
I know I could make this work by other means, but I'd rather hook it up exactly as designed.
Go away. 'Baitin.
Our Build: Mr. Beefy
