All the lights? Front, rear, inside?
Do you have a multimeter?
Use the continuity setting to find out what is shorting. Thomas runs ground wires, at least mine does, but the body is also a ground.
With everything off, you don’t even need the battery hooked up, but you need good fuses, go to each light socket and check continuity between the center contact (positive) and the outer shell (negative). If it sings you have a short. Do them all. After that at least you’ll have an idea of what circuits.
