Old 10-13-2021, 03:31 PM   #1
Coachwork: Michael Corbier
Chassis: GMC Savana 350
Engine: 6.5 Diesel
Post 9 volt wiring
I wired my circuit breaker panel as shown in my pictures. For some reason, when I turn the battery selector to off, current still flows to the swich panel. Any ideas why this happens?
There are no mistakes, just problems awaiting solutions
Corbi is offline   Reply With Quote
Old 10-13-2021, 05:24 PM   #2
Rwnielsen's Avatar
Chassis: TC1000, 40' MPV
Rated Cap: U/K
Why are there 3 wires to you battery switch? Should be power in from the circuit breaker and power out to your fuse block. Do you have a test light or a meter?
Rwnielsen is offline   Reply With Quote
Old 10-15-2021, 03:47 PM   #3
Engine: 6.5 Diesel
Post Reply about 3 wires from breaker
So, my circuit breaker has one wire going to the battery selector and a second wire goes to the power out of the selector. The 3rd wire connects the same terminal to the circuit breaker board. Maybe I should remove the wire to the circuit board from the power out to the power in terminal. I attached a photo from the selector instructions. I do have a voltmeter.
9 volt, circuit board, electric issue
