Originally Posted by Wpope86
I have a 1998 international 3800 t444e. I assumed that the bulbs for the gauges were blown because all the fuses look good. The gauges started working intermittently so pulled the instrument cluster out and re-soldered the main connector and now all the gauges are working perfect except for the lights that I even replaced with new led bulbs while I had the cluster out.
The instrument cluster lights are not coming on even with new bulbs. I also noticed the “wait to start” light is no longer coming on. The fuses next to the glove box all look good and the head lights turn on and off but no dash lights 🤷*♂️. What am I missing?
I would pull the cluster back out, disconnect the wiring and with an oh meter check for continuity on the traces in question. You might have a cracked trace.
I used to repair circuit boards for Apple computer monitors and you wouldn’t believe how a tiny hAirline crack in the board, especially where a component leg was, would kill a monitor.
Also, if you could I’d which wire powers the dash lights on the cluster connector, check for voltage there.
