Originally Posted by Ronigbzjr
In about a month time I should already have a bus and move into it full time. Right at the start, I'm going to engage with some heavy duty power tool work and need a basic off grid power system. For the demoing I'm gonna need to work with an angle grinder and various other tools (cordless, but needs to be charged obviously) but more importantly I'm gonna want to use a welder. I'm a relatively beginner welder, but I've worked in a metal workshop quite a lot recently and gained some confidence, so I decided that I'm gonna try raising the roof of the bus I will purchase. With these high powered requirements right from the start and the fact that I won't have an on-grid power source (probably gonna work on the bus on some BLM ground in Quartzsite) I'm gonna need to make sure I get a basic but powerful electrical system I can start with, and then upgrade later to be more flexible - but for now I just need bare minimum with enough power for my tools.
What do you guys think would be the best and most cost effective way to go about it? Should I invest in a solar panel so I can get at least some free power? Or should I just invest in a high quality generator and worry about solar later down the line? Maybe an inverter and just take the bus on trips a few times a day to charge up? A combination of all three? How does one do the math on these things?
Thank you for your help!
Our solar system is comprised of 12 325 watt sun power solar panels, 840 amp hours of lithium iron phosphate 24 volt batteries, 3 60 amp solar controllers, and a 10000 watt pure sine wave inverter. Those are the major components. Overall we have just less than $6,000 invested in our solar system. We can run any power tool that we like including Power MIG TIG welder. However we can do the same with a Champion 3500 Watt generator that you can pick up at Central tractor for about 325 bucks. Once you are done with your demo and you're ready to get serious with your build then you might think about solar power. Ruth and I like to stay comfortable so we were running the air conditioner in the desert of New Mexico All Summer Long on our gas generator before our solar system became sufficient. We don't miss spending $600 a month on gasoline. We also don't miss generator noise. And we don't miss having to fill up the generator and run for gasoline.
