Originally Posted by john61ct
SLA that is not AGM or GEL won't last long deep cycling anyway.
Use the AGM setting.
For LI you should look for charge sources with user-custom adjustments, not a limited set of canned choices.
AGM it is. Thanks.
Yes, I get that I'm not using them for their intended purpose. Yet, they are still good batteries and can be used for some 12v shed and bus lighting, greenhouse and bus water pumps. I just don't want to waste them completely.
I'm still not sure what house batteries I'm going to use. I do know LI is getting more affordable if you are willing to DIY, yet as you pointed out, there's more to charging and maintaining them then throwing them on a charger/maintainer.
