Ok, I'm in the beginnings of figuring out my power system. Looking at getting a small AGM deep cycle and mounting it inside rather than making a big power bank outside. I just have a short bus and will likely only need power for a night or two at a time, so I can get away with a smaller capacity.
Here's my question/concern. Charging rates. If I put this battery inside the bus, with a 12 gauge wire ran through a relay hooked to the main starting battery, and this battery is mostly dead when I energize the relay, will I fry something? Or will it just all work together and charge itself in a normal fashion?
I will likely put a small solar panel on the roof eventually, but I was just thinking of maybe like a small 25 watt panel or something similar.
Here's the battery I'm thinking of getting:
https://www.amazon.com/AB12180-Patro...dDbGljaz10cnVl
