Old 07-23-2021, 06:14 PM   #1
All in one Hybrid Inverter Charger with Solar Controller All-in-One
Hi guys,
I'm doing some research for my solar system and came across Hybrid Inverter Charger with Solar Controller All-in-One. These systems seem simple enough and easy to setup compared to the traditional solar system and the price is relative lower overall.
Anyone have any idea how well the Hybrid Inverter Charger All in One performs compared to the traditional solar setup? Any insights would be helpful as I'm at the stage where I'm about to finish framing the inside of my bus and moving on to setting up all the electrical and plumbing as well as installing the mini-split AC.
Thank you,
Thomas-TLTAdventures
TLTAdventures is offline   Reply With Quote
Old 07-23-2021, 06:27 PM   #2
Chassis: Ford E450
Engine: V10 Gas
No direct experience. Lots of products in this space. Provide a link and you may get more feedback.
I'm somewhat gunshy of all-in-one devices-if part of the system fails and you need to return it for repair, the whole system is down...
Old 07-24-2021, 01:06 PM   #3
Yes, "simpler" (as in supposedly easier to use) multi - function
is attractive to low information buyers
usually translates to poor quality, one part maybe fits the use case but the other(s) don't
Best is to educate yourself, and choose each device
sized for your specific objectives and preferences
and best of breed for each function
usually works out much better value long term.
Old 08-17-2021, 01:03 PM   #4
shaymcquaid's Avatar
Chassis: 40' MVP-ER
I use a pair of MPP 2424LV's in parallel.
I been using more than a year and they have worked as designed.
shaymcquaid is offline   Reply With Quote
Old 08-17-2021, 03:22 PM   #5
HamSkoolie's Avatar
Rated Cap: 31,800 pounds
Originally Posted by Rucker View Post
... Provide a link and you may get more feedback.....
^^^ What he said ^^^
It also depends on the needs of your system. For instance, if all you're doing is running a small 12 volt cooler and some lights, no air conditioning, not big draws, a simpler system may work. Jump up to a Class A with dual air conditioners, 110VAC refrigerator freezer, using a 110VAC welder on occasion.... you're going to want to go with the big boys and pump out the $1,284 (currently) price for a Victron inverter/charger/transfer switch and some hundreds more for the controllers, dongles, etc.
HamSkoolie is offline   Reply With Quote
Old 08-17-2021, 09:12 PM   #6
jofred99's Avatar
Chassis: TC2000-8 Window
Engine: Cumm ISB/Allison 2000
I've been running a GroWatt SPF 6000T DVM for about 6 months in my home and have been pleased with the performance. Due to lithium batteries, I do not use the charge controller.
The MPP Solar 3048LV-MK is what I plan on using for my bus build.
jofred99 is offline   Reply With Quote
