Old 09-28-2018, 10:41 PM   #21
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
Anybody use anythink like this.
https://www.sterling-power-usa.com/s...rycharger.aspx
I have 150 amp 24v alternator that powers the fans on my AC. I'm going to research building a 24 v house battery bank and wiring the alternator through a charge controller to charge the batteries when the AC is not in use.
There is lots of good information in the links PNW Steve posted earlier in the thread. I have more reading to do.
Ted
Old 09-29-2018, 12:34 PM   #22
I just completed the installation of a Sterling BB1230 in my little bus. I have just begun trials with it and this is what I've found to date:
1) STUDY the installation manual--lots of tricky concepts there.
2) Keep in mind Ohm's Law. Voltage equals Current times Resistance. When I first started the BB1230 it was playing to a brand new fully charged pair of Trojan deep cycle golf cart batteries. The BB was getting 14.4 volts from the alternator (12v, 110 amp) and outputting 14.6v. As a test I loaded the batteries with an inverter and all the LEDs I could turn on and allowed the batteries to draw down over night to 11.2v. I next shut off the load and fired up the bus engine. Same input voltage but the output voltage was down to 12.3v!???! After much gnashing of teeth I thought to measure the current input. I borrowed a DC clamp meter and discovered the BB was charging the battery at 26.7 amps--just shy of the 30 amp max output of the device. As a double check I disconnected the BB and switched on my house battery charger (a Progressive Dynamics 9245C converter and measured its output at nearly 45 amps--its max amps. I let the PD9245C charge the batteries up to 12v and then switched back to the BB1230 unit. All was well as the voltage output was again at 14.6 which was the charging voltage I had programmed into the unit. I like to look at it this way; if you monkey with any one aspect of Ohm's Law, the other two will change. A run down battery has less internal resistance to current (amps) than a nearly charged one. This explains the seemingly low output of the BB and its subsequent miraculous recovery on my test run.
3) Had I a larger alternator I'd have used the Sterling BB1260 (60 amp) unit to fatten up the charge rate. A 24v unit is also available in both 30 and 60 amps.
4) All the BB models are three stage and programmable to various battery types and requirements.
5) Since I use a standard 12v group 24 battery to start my genny and run the air compressor that powers the pneumatic door and the brakes on the toad, I feel comfortable with hooking it via manual switch to my start batteries/alt. The g24 likes to be drawn down quickly and recharged quickly as does the start battery.
Having had the typical experience with England's Lucas Electric (home before dark and all that) I checked out Sterling for smoke and finding none went with their product. We'll be on the road now for a week or so often dry camping and doing a good bit of driving. I'll have a better feel for the BB when we get back.
Old 09-29-2018, 12:45 PM   #23
TJones's Avatar
Chassis: CS RE
It sounds like your charger was working correctly. From my understanding the first stage is bulk charging and it is constant currant. The voltage measured is only an indicator of the charge state of the battery and will increase as the battery is charged.
Ted
Old 09-29-2018, 03:14 PM   #24
Want to hear more about this. I was just looking at the Sterling unit below...
ProSplit-R Zero Volt Drop Marine Battery Isolator - Intelligent Digital Alternator Distribution System (12V, 250 Amp, 2 Outputs)
https://www.sterling-power-usa.com/P...solator-6.aspx
Yes...I have a 250 alt. But that's about all I know. I am a total dunce regarding anything electrical and really need to hire an expert to help plan out a system. So far I am looking at all AGM's with a group 31 for the start and three 150AH units for house duty. Hoping to tie it all together so that I can charge all from the engine alt...or the gennny...or with a little help from a couple of 300w solar panels.
Absolutely no idea how to make it all (or any of it for that matter) work together. But I have discovered through chatting that your typical, household/trade electrician may know even less than I do about such systems. STILL trying to make contact with someone at a local shop that builds custom rigs for fire & EMS here. They have some pretty sophisticated gear on board with trick electronics to run it all.
