Mfg rating and paper docs will **not** tell you how many amps an alt will actually output for more than a few minutes or seconds, in **that** vehicle, in **those** ambient temperatures.
In real life, the VR fitted to the alt can be more critical than the alt itself.
Get an ammeter and a large high-CAR bank, depleted to 50% SoC and measure what the bank can pull.
If testing for an extended period, or if the bank just isn't pulling enough, might need a large load device as well, like an inverter feeding an adjustable electric heater, induction stove or similar.
Most stock setups, you might be able to pull half the rated max in even cool conditions.
If pulling big loads, rather than investing in a huge alt + sophisticated VR like Balmar MC-614. a DCDC charger will help keep V & A well regulated, protecting both the alt/VR and the load side.
