Originally Posted by ennonne
If you're talking about switches added by your body builder, not the 4 Ford upfitter switches in the dash, they probably are Carling Contura switches (or knockoffs). If so, yes, most Carling Contura switch bodies are the same. They are available in nearly endless configurations.
Carling Contura Rocker Switches Explained
One supplier:
OTR Switch Guys
They even do custom actuators.
They are a bit pricey though. I've had good luck at local junkyards that get the occasional shuttle bus or step van to pilfer from.
they are most likely the switches provided by the body builder and not Ford. They are installed on the top of the dog house just a few inches from the cup holder.
The 4 switches appear to be unlabelled with exception to the first one on the far left, it has the symbol for lights but opens and closes the side doors. The other switches are #2 = interior lights, #3 lift power, #4 fast idle on/off
the bus will be going to the mechanic later in January and that might be a real good time for him to take a look at the switch bodies and find out what they are in regard to amperage, type, terminals, etc.
