Originally Posted by dbsoundman
That being said, I looked at DC-DC charge controllers and holy crap they are expensive! (At least the Sterling ones, I don't trust Renogy, nor do I trust the Amazon brand du jor.) So, is there some other simple device I can find that will simply pass voltage when it senses an input voltage that's alternator-level (>13 volts)? Or am I stuck with manual switching until I get a DC-DC charge controller?
Just search Amazon for dual battery isolator. They might peak out at about 15 amps, and only work with lead acid batteries. I know of no cheap solution for non-lead batteries.
I have a factory DC regulator between my main battery/alternator and the second chassis battery. It charges the second battery somewhat after the primary starter battery is fully charged. Off of that secondary chassis battery I have an isolator like the ones listed on Amazon above that connects 2 additional chassis batteries.
It works great keeping the dual spares charged up, and if I accidentally run down the main batteries I press a button and the dual spares come on line to start the engine.
None of these are connected in any way to the LiFePo house battery right now, but I have a Renogy 20A DCDC charge controller which will provide the right charge profile for the LiFePo battery when I'm driving.
