batteries that can take numerous cycles?
as I build out my glass cockpit for the redbyrd.. I am facing a unique challenge. I am using a raspberry pi to do my switch panel..
when I shut the bus off, the touchscreen will go off on a timer override, buit I want the computer to stay on for 'X' amount of time to stay awake and not have to be shutdown and rebooted if im say running errands and such.
the computer pulls a couple watts when it goes into idle mode.. so over a long period of time that would run the bus batteries down if I left it on..
my thought is to have a second much smaller battery that the computer runs off of.. I wantto be able to cycle that battery down somewhat low until a GPIO would detect low battery and execute my shutdown sequence and kill the computer till I powered it back on..
my trick is in findinfg a battery that can be run down to say 50-60% and then stored that way.. as this would happen when the bus is parked for long enough to trigger the shutdown.
the plan is to have a dash switch for this but I know ill forget to use it so I want a battery that works with my forgetful brain..
the other thing is the battery will get stored cold... I live in ohio.. I do plug the bus into shore power so I could keep a maintainer on it when shore powered.. but again things happen.. power goes out at the storage place.. I forget to connect it.. etc...
do I just need to put in a really oversized battery that I would only drop to 80% and then charge back up ?
if I go lithium I want a battery that is automatic.. something with built in BMS....
is what I want to do just hard on batteries?
