Originally Posted by mitchk
Alright so I already have run into another question. I will probably use around 8AWG to wire my charge controller to battery bank. I am putting a fuse between the solar charge controller and the battery bus bar. I'm assuming I would want to put the fuse as close to the charge controller as possible since power will be starting in the charge controller and going to the battery bank. Or is their a failure scenario where the power would actually go backwards from the battery bank to the charge controller? If that could happen would I actually want the fuse closest to the battery bus bar?
So I don't have a good answer for you, but it is a good question, and thinking things through at this level puts you way ahead of the crowd. I asked a similar question
here and received some useful feedback but not a clear answer. Some charge controllers have internal fuses in which case it probably makes more sense to place the fuse or breaker closer to the battery (this is probably what I will do). I think this is a good place to follow your manuals recommendations if it gives one.
So long as you use properly sized wires for your PV array and controllers max output, and have circuit protection somewhere in the circuit, you should be pretty safe I think, regardless of the precise location.
I think sproutroot and DrewBru are right:
Yes, breaker on both sides of the controller. Drew Bru's method of turning off the panels is correct [disconnect pv array first].
Also I'm assuming I would want a master switch to turn off charging the batteries. I would want to put that switch between the solar panels and charge controller right?
Correct, a breaker or switch between your PV array and your controller is a good idea. I also plan to have a main battery switch to disconnect the battery from the rest of the system.
put fuses in between the batteries and bus bar? I am wiring my 3 batteries in parallel directly to the bus bar and not with each other and then to the bus bar.
As a best practice you want a fuse as close to the battery positive terminal as possible (ideally right on it). What that means in practice will depend on the specifics of your situation.
But if you switch off the line between your charge controller and your batteries isn't that really bad for your charge controller
This is (or was) the conventional wisdom. Victron used to explicitly warn against this, but recently has recently stopped warning against doing this. My recollection of their explanation is that it was a theoretical problem, that turned out not to be an issue in practice. See
post #43 here the person replying to my comment is a licensed Victron support tech, and the person he is referring to 'Matthijs' is Victron's CEO, so I trust this answer, at least in terms of Victron products. But always follow the recommendations of the manual for your specific charge controller unless you are sure you know what you are doing! And as a best practice, I think its still best to follow the conventional wisdom, even if its not strictly necessary its still logical to disconnect things at the source.
