Old 04-01-2024, 01:58 AM   #1
battery bus bar
I just picked up a 2011 international IC FE
The battery tray is a mess, it seems to me to many things are hooked up off the wrong batteries.
It has 3 (12 volt)
Now shouldn't all the negatives be off battery 3 and the positives be off battery 1.
Right now there's a bunch hooked up off battery 2
I want to clean it all up and run everything to bus bars and then just have two cable running from the batteries to the bus bars
Can this be done using a 1000 amp bus bar.
Thanks for the feedback.
Sminoletti is offline   Reply With Quote
Old 04-02-2024, 08:40 PM   #2
nikitis's Avatar
Rated Cap: 29
Yes it should work as long as you match positive to positive bar and negatives to a negative bar (assuming multiple negatives).
The negative on sum buses have two thick gauged wires coming off. One goes to the Bus Chassis to ground, and the other goes back up to the starter. A Bus bar could also be made for that as well, but obviously separate from the positive.
My battery tray was a mess as well. You can tell all sorts of dudes worked on it miss wiring everything, and my VPM was fried likely as a result. I re-wired it before they replaced the VPM and it's worked great ever since.
Also in such a configuration if you plan to run a battery disconnect I recommend a short wire from negative of battery 3, to the disconnect, and then from the disconnect to the negative bus bar you'll be adding.
Good Luck.
