Old 07-06-2021, 09:17 AM   #1
Year: 2006
Engine: Mercedes Benz diesel
Battery Compartment Door Hinge
Hey everyone-
Does anyone know where I can find a door hinge for my battery compartment? I thought about 'Jerry-Rigging' a few of my old cupboard door hinges, but would like the bus to look nice not just thrown together. Do y'all think a longish piano style hinge would work or should it be more weather rated.
Thanks tons.
Therese
Therese is offline   Reply With Quote
Old 07-06-2021, 09:32 AM   #2
You can find light duty piano hinge at the big box. You can get heavy duty at the steel supply house
You might be OK with the light duty one. Have someone with a spot welder attach it to the door
Old 07-06-2021, 09:50 AM   #3
Chassis: Front Engine
For stuff like that check out Austin hardware
https://www.austinhardware.com/all-products/hinges.html
Or unity bus parts
https://www.unityparts.com
I think Austin is a better bet for those but two really useful stores regardless.
rffffffff is offline   Reply With Quote
Old 07-06-2021, 09:52 AM   #4
Chassis: Ford E450
Engine: V10 Gas
and only use stainless steel hinges on the outside.
Old 07-06-2021, 10:45 AM   #5
flattracker's Avatar
Engine: Cummins 350 big cam
Rated Cap: 86 passengers?
I got a stainless steel piano hinge at Fastenal. They had to order it but I got the right one. You need to spec the various dimensions to get the right one. I agree, use stainless outside.
flattracker is offline   Reply With Quote
