Old 06-17-2021, 04:27 PM   #1
stlthe's Avatar
Chassis: Saf-T-Liner MVP EF
Engine: Cat C7
Rated Cap: 29 (Perimeter Seating)
battery compartment/master cutoff question
Hi
Can anyone tell me what the circuit breaker is in this pic and what it is connected to? It has been removed not by me and I'd like to replace it. Can anyone give me a clue? It is hard to tell just by looking, i'm hoping someone has seen this before. It is a BUSS 90 amp with manual disconnect/reset.
Also, is it common to have lots of rust in the battery compartment? There is more rust there than about anywhere in the bus.
Thirdly, my master cutoff switch operates on the positive side instead of negative. i understand it is better-off on the negative leg. Is it worth redoing the whole thing for the protection of ecm/tcu from spikes?
thanks
Evan
stlthe is offline   Reply With Quote
Old 06-17-2021, 05:14 PM   #2
Chassis: TC/2000
Engine: 5.9 Cummins 12-valve
Rated Cap: 1
Originally Posted by stlthe View Post
Hi
Do you have a wheelchair lift? It look's like what I have on a Thomas with a lift.
Is there a drain blocked or is it on the top and sides?
Some feel that it is better on the negative but I have a Blue Bird Vision with a factory installed shut-off on the positive side. After market types can touch metal and cause arcing.
thanks
Evan
BamaBus is offline   Reply With Quote
Old 06-18-2021, 03:57 AM   #3
Acidic fumes from batteries are very corrosive over time.
There are acid-proof paints specifically designed for coating the inside of battery trays and boxes.
