Old 02-12-2023, 03:12 PM   #1
Chassis: DT444
Engine: 7.3
Best Batteries
What is the BEST lithium batteries for my new skoolie, I'm in Florida and will have split AC unit.
Fishfry is offline   Reply With Quote
Old 02-12-2023, 07:10 PM   #2
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Well, that's a can of worms. There are lots of factors...cost, format (rack?), weather conditions, BMS preferences, etc.
For cheap options, the Chins are pretty impressive.
For US support, I like the Dakota Lithium and Battle Born and SOK and Big Battery
Old 02-13-2023, 08:47 AM   #3
HamSkoolie's Avatar
Rated Cap: 31,800 pounds
We are sold on the EG4 LL batteries sold by signature solar. Since our system is going to be called on to run two A/C units and store the power from 2900 watts of solar we have two 24 volt units that will be put in series for the 48 volts that our inverter (also signature solar) requires.
The EG4 LL's are 5.12 kWh batteries with built in BMS, communicate with a PC for setting parameters and monitoring, and have built in on/off switches or circuit breakers (for on/off). They're a bit expensive at $1500 but they are only 101 pounds and roughly 20x20x6.1" each. The $1500 version has a 5 year warranty. The $1750 version (with LCD screen on the battery) has a 10 year warranty and is spec'd for 7000 cycles (19.5 years) to have 80% remaining capacity.
We think they're the best bang for the buck unless your system needs are much smaller.
HamSkoolie is offline   Reply With Quote
Old 02-13-2023, 10:30 AM   #4
Chassis: Ford E450
Engine: V10 Gas
Lots of questions. Do you have a power budget yet? That is, how many amps of storage you will need?
