Ok, I think we got way off track to your original question.
Im in the same situation, though I have 990W of solar and 3.5kw battery.
Winter solar hours, full time in the bus, regularly running appliances, etc I find myself sometimes in the same posittion.
What has worked for me is to rely just on two things.
1:
Isolator relay and Dc-Dc link for my house battieres.
If i drive the bus I can see 20A & 24vdc going into the batteries.
This recharges my system up by 50% after 4-5 hours on the road.
2:
Shore power.
When I know its going to be cloudy, and cold for the next several days. I will find somewhere I can plug into shore power overnight.
If I find somewhere to plug in ( campgound, rv park, picnic area outlet, exterior of some building, parking lot where the street lights have an outlet behind the screwed on cover, etc.) then I can manage to just top up using shore power overnight and be good for a while.
You mentioned you would need to use this once or twice a month...
Between driving somewhere once a month, and finding shore power once a month you got your problem resolved. Try that.
I don't have a generator, or anything like that, If I needed it regularly I would use it. but for me having the shore power connections works out perfect when I need it.
