Old 10-17-2021, 06:49 AM   #1
Best solar batteries???
Hello fellow skoolers… I’ve been living out of my conversion for about 4 years and out of nowhere my batteries started not getting fully charged, and as soon as I put load on the they shot down super quick. I have two hundred watt panels with two 6volt Trojan t105’s and a wanderer charge controller. I’m guessing it is the batteries not the charge controller because when I put the load tester on it reads bad. The Trojans have done me well for 4 years, but they are pretty expensive. Does anybody have some favorite lead acid 6 volts they use?
Lherrlinger is offline   Reply With Quote
Old 10-17-2021, 07:55 AM   #2
The best battery value by far is Duracell (actually Deka/East Penn) FLA deep cycle golf cart batteries, 2x6V, around $200 per 200+AH @12V pair from BatteriesPlus or Sam's Club.
NAPA relabels it here: https://www.napaonline.com/en/p/NBP8144 Deka self-labeled also sold at Lowes.
Old 10-17-2021, 08:04 AM   #3
Make sure for better longevity
charge to 100% Full most cycles, 2-3 times a week minimum, at 12V:
Absorption Voltage = (14.4V -) 14.7V better
Absorption End Point = Current change over 1 hour period of less than 0.1A
Max Absorption Time = 12 Hours
Float Voltage = 13.4V - 13.6V if long periods, 13.8V - 14.1V for say just a day
Equalization = 15.0V to 15.3V
Equalization End Point = Current change over 1 hour period of less than 0.1A
Max Equalization Time = 12 Hours
Temp Compensation = -.018V for every degree °C rise above 25C
Old 10-17-2021, 08:05 AM   #4
Make sure for better longevity, going below 40-50% SoC is a rare occurrence occasional emergencies.
Old 10-17-2021, 08:07 AM   #5
Or just stop when current drops to 0.05C, or 1A per 12V pair
Old 10-17-2021, 12:57 PM   #6
So I have the renogy wanderer charge controller and it is “supposed” to do all these things by itself I’ve gotten 4 years out of them…. I wish it were more but what can I say. Any idea the power of those duracel batteries vs the t105’s? As well as size? I think my t105s were around 200 a pop as well
Old 10-17-2021, 03:01 PM   #7
Google for the Deka/ Duracell sizes
black one is the GC2 - 215AH Deka Pro-Master GC10,
gray one is the EGC2 - 230AH called the GC15,
a 235AH is the GC25
Deka delivers a quality battery, especially for lead, and for the price. But if you can get T-105s locally for within say 15% of the per-Ah price, go for that.
Other top notch true deep cycling FLA makers besides EPM and Trojan include U.S. Battery, Crown and Superior.
Rolls/Surette is in another league and priced accordingly.
_______
Renogy is not great, they just market relabeled low-ball cheap chinese.
They used to have great CS attitude, now not so much.
But never fully trust any charge source, even with an $800 charger, always verify periodically at the bank posts with your own separate known-good DMM and ammeter.
batteries, help me, power, solar, trojan
