Old 08-09-2023, 10:09 PM   #1
Coachwork: Blue-Bird All American RE
Chassis: F204270
Engine: Cummins 8.3 ISC
Bluebird folks, HELP flashers
https://photos.app.goo.gl/Qbbw49z2hTNgyfJm8
We went through wires today from the driver's side panel to the light bulbs and found a Short the PO created in the rear and 2 bulbs were corroded.
After those fixes, there still is nothing flashing or emergency flashing. I linked some pictures.
I found an ad for a yellow flasher bu tin the same add was a black box, If you have the Yellow flasher does it require the black box? Included some picts of the black box ads. Also in by the relays there are 4 boxes marked 12-1 any idea what they are?
thanks in advance, really need to get the flashers fixed and get the bus moved.
jfmusic@me.com is offline   Reply With Quote
