Actually N+1
So 8S pack BMS has 9 balance leads, plus the power pair(s)
Just keep you charge & discharge rates well below the max rating and you'll be fine
nothing to do with the Ah capacity of the bank.
Paralleling BMS is fraught, unless a proven trusted electrickery wizard who has done it with that specific model is guiding you, best to avoid.
A good BMS with high power rating can cost hundreds. Cheap ones, keep your eye on them, they can murder a bank just as much as protect one.
