DeMac, could not have done this without you. I missed the PM part, this wasn't time sensitive. I have another year or two on this project.
Couple questions, as I still am a bit confused on minor things.
To energise the second breaker....should I ever need one. You mentioned earlier.
"You're service ought to be 10/3 (or 12/3) im hip to upsizing to 10.
Blk, red, wht, grn. One current carrying conductor, per breaker. The breaker termination is for only one wire, no joint."
Does that mean I can use the RED wire as the HOT for the second breaker?
Last bit about the Inverter "ground lug". Its NOT green, its silver. If I connect it to the Ground bar in the panel, I show an "open ground" with my tester. If I connect it to the Neutral bar, I show a good ground.
Checking a Victron site, we can see
this schematic...
Mine is 12/1000 not 24/1000
Just wanted your thoughts on this. I don't want to take more of your time on this, you've been super helpful.
Peter
