Bus won’t start - Maybe rear exit issues?
I have one of the short busses and have always had a problem with the rear safety alarms getting started and never looked to take them off. Would just open and shut the doors multiple times till it would get started. Now we can get the bus to start at all and need help as I am not sure what to do.
When I turn the key everything gets power but it won’t even try and turn over or make any noise when you try to start it. I have taken off both of the rear exit safety units thinking that would be the problem and followed some guidelines to bypass them so they are not needed but it still won’t start. Can someone suggest anything else? How exactly do these safety switches work, do they disable the starter or is it disable something else? Just wondering if I could bypass or get it started another way by changing out a wire in the engine or some other part.
