Old 02-27-2021, 06:04 AM   #21
joeblack5's Avatar
Year: 98
The second battery hangs on the passenger side of the frame...the girardin buses have a battery box directly after the door...
The batteries are directly in parallel.
Often the second one dies earlier.. not sure why.
The early e350 had both in the front. The passenger side one was specially made for ford and expensive.
If you are diy.
The frame ones are a pain to get of. The box hangs on safety cables and you have to tilt the batteries in, make the connection and the lift it back on / over the bolts.
Good luck
Old 03-01-2021, 01:04 PM   #22
AmandaandMarky's Avatar
Where could I bring the bus to have something like that done?
AmandaandMarky is offline   Reply With Quote
Old 03-01-2021, 01:19 PM   #23
Johnny Mullet's Avatar
Engine: T444E 7.3L
Where in NY are you? I am in NE Ohio near Lake Erie. I also work at a shop in NW Pennsylvania close to I-90.
Old 03-03-2021, 01:36 AM   #24
I’m smack in the middle, Utica, close to Syracuse if you know whereabouts that is, I wish I was a bit closer to you, if it were any other issue I’d just make the trip since we want to be traveling south anyway, but with the bus only starting with a jump it would be a risky trip lol
Old 03-03-2021, 04:31 PM   #25
Chassis: 3500
Engine: GMC
Rated Cap: 8 handicapped
You want to search for a parasitic draw and fix it or you'll likely end up with 2 dead batteries instead of one. Really should not need more battery than the vehicle came with stock.
jackdebear is offline   Reply With Quote
Old 03-03-2021, 08:17 PM   #26
Coachwork: Bluebird, Collins
I have a 1992 E350 shuttle bus with two batteries in the front. Itís just used for storage currently. I am also having phantom load problem and left a charger on each battery. I got tired of doing that so installed two 40 watt panels that were gathering dust. One for each battery. When I opened the junction box on the panels I found tiny little charge controllers inside the boxes. So that was a craigslist surprise bonus. Maybe this Summer Iíll locate the phantoms and install a cut off switch. Iíll be curious to see if the panels got the batteries through the Winter when I return. Ive read of healthy fully charged lead acid batteries being stored in a shed over winter with no damage. Perhaps thatís what I should have done. Iím no sure how healthy these batteries are so went with solar.
A DMM (digital multimeter) usually has a ampmeter rated for 10 amps. That should be plenty for phantom. As Be Nimble suggested, pull one fuse at a time until you see the culprit.
Doktari is offline   Reply With Quote
Old 03-03-2021, 09:10 PM   #27
Chassis: 3500
Engine: GMC
There's lots of youtube videos about how to track down a parasitic draw.
batteries battery
