https://www.skoolie.net/forums/f10/h...ock-10956.html
The vandalock system is not allowing you to start bcuz something is open, OR if there is an additional bolt action lock, that lock must be unlocked. (first responders need to be able to get in.
The above thread, I think, discusses disabling the vandalock system for a bus like yours. Then you can pull the locks and buzzers as you like.
That particular thread didn’t work for my 2001 Thomas.
I ran a wire from the “ST” terminal on my key switch to the button in the engine compartment, bypassing the window and door checks. The rear button is intended for the mechanic who doesn’t need to worry about closing windows and doors. The buzzers will still go off so just pull em.
Good luck! [emoji3522]
