Originally Posted by budbud7
Wow! Thanks ew01 for this treasure chest of information. I will review this information and start searching for a bad wire or switch at the location. BamaBus also stated the emergency roof hatch could be a problem. It hadn't crossed my mind that those doors could be on that circuit. I have opened only one of them some time back. I have some direction and I need some time, perhaps the weekend. I'll let ya'll know when I find something.
Take a look at the wires for either the roof vent or door latch. The wires on an International are color coded and numbered. The number will help you locate it on the circuit diagram.
Take a look at both and see if they are the same color and same number.
If you removed and replaced any of these wires could very well be that it is installed in the wrong place or making contact with the bus body if it is hanging loose.
Take a look at the door that you mentioned you messed with earlier, could it be that maybe that wire is touching ground/bus body?
I have all mine disconnected at the switch itself which means...no buzzer ever!
