Hi, assuming this must be the first time trying out the power situation in an RV park in your converted bus?
Make sure there is power on the power pedestal, the source. They are not always left in the "On" position. Verify for power, 110vac, with some sort of tester if you don't have a meter for this. A radio, a drill, hairdryer etc will suffice.
When sure of that fact, plug the bus into that and make sure your main switch coming in to the main panel is on. Could be that simple, you not knowing what is what yet.
good luck, keep us posted.
