CAN bus button swap
I have a 2007 INTL CE300 - with a CAN bus obviously. Issue at hand, the steering wheel buttons are for the flashers and door. I have relocated the door button by tapping into the leads for the motor. I have disconnected the steering wheel buttons as every time they would be depressed, I would have to go through the NCLOB procedure and since I removed the switches for the doors long ago, the bus would go into alarm mode.
I also have cruise control on the dash.
These switches are not dumb switches and have ICs on them.
I bought replacement steering wheel switches for cruise control and thought that because CAN bus... well I was hoping that the data network would have identifiers on the switches and just work.
The question I have is what is the best way to get the -new- switches on the steering wheel to work with the cruise control and remove the old cruise control switch bank all together.
Would splicing actually work or is it really a data network with protocol? If the later, why wouldn't my new cruise control buttons work instead of still controlling the flashers?
Is there a method to program the BCU instead to switch locations?
Thanks...
