06-15-2021, 07:02 PM
Can I have 2 battery banks ?
Hi yall.
Ok I have 4 3.2v 100ah LI batteries connected in series(I believe that's correct) to become 12v 400ah LI. And I also have 2 200ah 12v gel batteries connected parallel.
I also have a dc to dc alternator/solar charge controller.
And a regular solar charge controller.
Oh and a 2000 w pure sine inverter charger
And a 3500 w inverter.
But they are different brands.
I was wondering how/if i can use both battery banks together. If I can how?
And if I can use both banks can I use bother charge controllers? What about the inverters?
Also
I sadly only have 300 watts of solar.
Do you think I should get more solar
06-15-2021, 07:23 PM
I think the issue would be that each bank of batteries is a different chemistry .. likely has a different charge and float voltage.. you definitely only want batteries of the same voltage and charging profiles together...
06-15-2021, 07:39 PM
Chassis: Ford E450
Engine: V10 Gas
I have my 'original' double lead/acid batteries linked in a bank behind an isolator and connected to the chassis batteries, but completely separate from the 280 AH LiFePo setup.
I researched linking up those two banks, but ultimately decided to leave the lead acid batteries in place but not connect them to anything. The charge requirements and controls are different and it just seemed silly to invest in more equipment to try and leverage that system. They function well as a jumpstarter setup (used it once when I flooded the engine).
06-15-2021, 08:21 PM
Year: 2009
Coachwork: Gillig
Chassis: G27E102
Engine: Cummins ISL 280
Rated Cap: 26,000 lbs
It IS possible to do this (combine chemistries), but it’s not worth your time or the investment. It’s a mess, and generally a bad idea.
As KC says, they have different voltages, but there’s a way to deal with that. It’s always going to be a kludge.
300W isn’t a lot, but it’ll give you 1.5kWh on a sunny day. That may or may not be enough. It’s definitely not enough on overcast days or during the winter.
If you are hell bent on using both, get another few hundred watts of solar and have two parallel, unconnected systems.
If you have an abundant supply of used lead acid batteries in the future, use those. Otherwise, when the lead acids die, move the whole system over to LFP.
You have two battery banks, you have two inverters. Solar is cheap and so are charge controllers. Easy choice!
06-16-2021, 12:10 AM
Year: 2013
Chassis: IC RE
Engine: HT570 / 3500SP
Rated Cap: 4
Originally Posted by Misfit_offroader
Hi yall.
No, ah doesn't add up when in series. You'll get 12v 100ah.
06-16-2021, 06:22 AM
Chassis: Amtrans
Engine: 444E
Rated Cap: 84 pas
Hi yall.
Also
When you connect in series, the voltage adds up, the current capacity remains the same. 3.2 *4 gets you the 12v at 100 AH.
Do you need more solar? Lol. We have 327W x 12 and we are thinking about finding real estate for four more.
We have 6 BYD 24V 220AH batteries in parallel for 24v x 1320 AH. Of course we would like 2 more.
You can have 2 separate battery banks of different chemistries, however not on the same solar array.
06-16-2021, 10:54 AM
Chassis: International RE
Engine: International T444e
Rated Cap: 76
I would not combine banks like others have said. However you could charge each battery bank, each using their own charge controller but the same PV array. For AC charging you'd need one charger per bank.
One pattern is to combine them with a battery selector:
https://www.amazon.com/Blue-Sea-Syst...3854907&sr=8-4
Use the lithium, then if that ever runs out on you, you can flip over to the lead acid. Nice little backup.
Another pattern is to put different loads on different banks. Inverter on lithium, sippy DC appliances on the lead acid. Same concept- two charge controllers, same PV array, or one AC charger per bank.
Could also use the lead acid for dedicated use cases like a winch or external lighting.
Also, put at much solar up as you have space, budget, need for.
06-16-2021, 01:18 PM
Engine: DT466E, Navistar
To further clarify what others have mentioned:
When you connect batteries in series, the voltage is multiplied, but the energy density remains the same.
ie - 4-3Volt 100Ah batteries wired in series = 12Volts 100Ah
When they are wired in parallel, the energy density (AmpHours) is multiplied, but the voltage remains the same.
ie - 4-3Volt 100Ah batteries wired in parallel = 3Volts 400Ah
Another example could be 2 pairs of the batteries wired in series, and then those 2 pair wired together in parallel (also known as 2S2P), which would = 6Volts 200Ah
06-28-2021, 03:17 AM
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
OK, got lost here. 1 step at a time. How do the 2 charge controllers split up the time on the panels? Can they both use the panels at the same time?
06-28-2021, 12:45 PM
Rated Cap: 76
You can connect multiple MPPT chargers to the same set of panels, same as if you had multiple DC devices connected to a battery. Who will get how much power if there's not enough PV to fully satisfy both controllers is hard to say.
Lets say you have 200W of solar and two 12V 10A MPPTs connected. The MPPTs can in theory draw 240W total, but given there's only 200W available, that 200W will be split between the two MPPTs in some way. It could be 140W to one and 60W to the other, down the middle, or otherwise. Many MPPTs you can configure a rate limit to help facilitate this.
Also, the bank less used is more likely to remain (near) full and not need much to stay topped off.
06-30-2021, 03:20 PM
Coachwork: Our hot little grubbies...
Rated Cap: Five Heelers
2003, we converted a 1997 Ford CF8000 commercial truck to our concept of an ExpeditionVehicle.
Our photovoltaic array is six 305-Watt panels for a total of 1,830-Watts.
These feed our AGM bank.
Our AGMs were new in 2003, and we rarely empty them past a couple-three percent.
Q -- Do I think you need a larger photovoltaic system?
A -- I think you could live with it a while as you learn to reduce your needs.
One of my guilty pleasures is reading the posts at IRV2, a massive forum for owners of the equivalent of Shiny! BillionBuxBus conversions.
Dang!
Factory Shiny! RecreationVehicles are insanely complex, requiring TrainedPerfessersionels to unravel their mysterious ways.
I think building rather than buying Shiny! is a better idea.
