Chair lift circuit breaker location 2009 Minotour
Good Evening all,
I removed my chair lift last year, to kill the power, I disconnected a wire coming off the positive post in the eng compartment in my diesel mini. That done, I though heck, piece of cake. I taped off the loose wire that I disconnected. Fired up the bus, no issue, but when I tried to close the loading door, nada.... I then reattached to power cable and the doors closed.
I want to install a black tank in the rear of the bus and the power supply cable is running on top of the frame rail where I want to place the tank. I suppose I can pull the cable through the floor and reroute it away from the frame and seal it off good and stow it underneath the bus, but I"d prefer to kill the power permanently and stow the dead wire below the bus.
I don't see any circuit breaker or relay for the rear door.
Thank you in advance,
Don
