Old 03-31-2023, 03:20 PM   #1
Year: 2008
Coachwork: Collins Grand Bantam
Chassis: Chevrolet
Engine: Chevrolet 6.0 gas motor
change to led light fixtures or just led bulbs on outside of bus?
is everyone changing the entire light fixtures or just putting in led bulbs?
would love to hear what others did, i definitely have enough projects on this so debating being lazy and changing the bulbs
Vin1 is offline   Reply With Quote
Old 03-31-2023, 03:40 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
all of my marker lights and tail running brake reverse lights were changed to LED fairly cheap.
look at partsam on amazon.
the front neadlights and turn signals have not been changed yet.
to change to LED bulbs you have to add a resiistor or something like that and by itself is like 60$ not counting the bulbs.
everything else was simple and straight forward.
Old 04-23-2023, 07:00 AM   #3
Engine: 8.3 Cummins mechanical injection
Some of my lenses were cracked, so I got all new led turn signals and brake lights, and new incandescent reverse lights. I got them from tac bus parts. The leds are much brighter and they were about $30 each. I kept the incandescent turn signal on the side of the bus because it was still in good shape, but without it connected the flasher wouldn’t flash. If you have all leds you have to replace the flasher as they don’t draw enough power to make it work
Jackula is offline   Reply With Quote
Old 04-23-2023, 01:16 PM   #4
Year: 2008
Chassis: Chevrolet
very good info to have on the flasher!
thank you
