Originally Posted by Simplicity
To be clear, does the BMS disconnect the entire battery from loads if even one cell falls below its rated voltage?
A good BMS does this, or at least has a mechanism to do so. This is to protect every individual cell in the pack.
The idea is that you shouldn't deplete the battery to the point of damage, the cutoff voltage is around the area damage or an otherwise unsafe condition is likely to start occurring. Same with charging. If the charger doesn't stop in time something else has to, or you may get a fire.
I'm assuming if each cell is 3-4v, then you have 3 to 4 cells in series (~12v) and those series banks are in parallel to build up the amp hours?
NO- best practice mandates you wire cells in parallel FIRST and then wire those cell groups in series. This is why I don't like drop in replacement lithium (like battle born), those batteries are internally wired in series, but you see a bunch of people out there running 2 or 4 of them in parallel. In no other context is this considered acceptable- if you do series then parallel with a DIY pack you will have people on the solar forums hounding you about it.
Parallel first is why I'm abandoning Tesla packs (which are internally wired in series) for LiFePo4. You can series connect packs safely, but parallelizing them at any scale will cause longevity issues and introduces some pretty nasty catastrophic failure scenarios.
My new bank is wired 3P16S. 3 cells wired in a Parallel group, 16 groups in Series. 48V (51.2V Nominal). If I want more capacity I bump all 16 groups to 4 cells or more.
So, why doesn't the BMS just take the one bad bank out versus the whole battery? Be nice if it did that and then texted you. Ha!
Because its a failure condition that can damage the battery or worse cause a fire.
When recharged from low-voltage cutoff, the BMS will once again allow loads. When the highest cell is discharged below maximum voltage, the BMS will allow the pack to charge. The BMS keeps the pack in a safe voltage range for long term operation.
