Originally Posted by AXett
I don't believe it was converted - all has seemed pretty "vanilla", came from a school auction. Is it safe them to assume if I blow one of the OEM "24v" fuses, I can swap in a standard fit 12v automotive fuse?
fuses are designed for current protection not voltage protection.
There are other devices that provide voltage protection such as diodes or voltage regulators.
Essentially you can have a very small gauge wire, say 26 gauge, and run quite a high voltage on it. Lets use 110 volts....what is critical to know/realize is that it is the amount of current on that wire that is important !
A 26ga wire at 80c can handle up to 4 amps through it. it then starts to get warmer and eventually hotter , burning the wires as you increase the current flow on that wire.
fuses are just like that little wire...the thicker the wire the more current it is capable of handling.
18ga wire at 80c can handle upto 15 amps.
So if you look at your fuses you will see that the little wire in the fuse gets thicker as the current rating increases and that is so it can handle the heat generated from the current flow.
To go back to your concerns, on a bus it really doesn't matter if it's rates for 12v, 24v or 110v. Your bus wiring is based on a 12volt system.
There's more to know but this is the basics....
