Hello fellow Skoolers,
I removed the child safety monitor (the one above the drivers seat). This monitor has wires going in then out to bridge the gap between the fuse panel, I’m guessing, and the turning and brake lights.
Now that my child safety monitor (bridge) is gone my lights wont work.
There would be way too many possibilities to try one at a time with a little jumper wire without knowing where they should go.
The wires have numbers but don’t seem to correspond with the wiring diagram for a 97' International. They has to be a pattern but I can’t crack it.
Ive called Dorian who makes the products but they’ve never heard of the old timey device I had. It’s one that has 6 white huge cluster plugs, 3 on each side. Ive looked on eBay and couldn’t find any used ones.
2 Options:
- Make wiring alterations to the plugs if I know where to make jumper wires
- Find a child safety monitor
If anyone has info that could help me get my lights back to working that would be extraordinary! Hopefully I can help you too!
