Also need help with clearance/marker lights.
08 Gmc Savana 6.6 BlueBird
So annoyed. I noticed a loose rear brake bulb so like a fool I stuck some wire behind it to make it tighter inside the socket which overloaded the circuit and killed both my brake lights and clearance marker lights. Under the hood i found a burnt aux stomp lamp fuse which fixed my brake lights when i replaced it, but my clearance/marker lights still remain dead. I have no idea how to identify anything in the blue bird fuse panel even though i have access to all the wiring diagrams,(Hard to read as a novice.) there are only two actual replaceable fuses in the bus fuse panel the rest are self resetting breakers. Any help is greatly appreciated I gotta get these damn kids to school!!!
