Originally Posted by Winter-Vale
So we (foolishly) built the electrical closet inside instead of in underbody. Everything in there: battery bank, charge controller, inverter. etc . The closet gets HOT. I want to cut a vent and install a small two way fan, probably on the 9V panel. Has anyone vented their onboard utility closet?
All of our Solar Controllers are indoors. We used a heater blower out of another bus we have in conjunction with this nifty thermal controller
https://www.amazon.com/dp/B019I3YCFS...roduct_details
to move the hot air outside when the temp in the controller closet rises to 100 degrees. It shuts off at 89 degrees. We set it that way so that it could reach a shut off point if we were out and about and had the air conditioning off.
Had you placed your electrical box under body you would still want to deal with keeping it ventilated and now you have the additional challenge of keeping the dirt out.
Depending on where you go or where you live you want to keep your batteries warm when it is cold.
our 30KW battery bank resides under our king bed and has an electric under floor heating mat for wintertime. This also provides about 60% of our heating needs all winter long. Once the batteries are up to 70 degrees F, the thermal mass radiates out to the bed and from the bed to the rest of the house.
