Old 12-06-2023, 01:11 PM   #1
DC > DC Charger Ignition Wire Placement
Iím getting ready to install a Renogy 20A DC > DC charger in my bus. Iím looking for an easy connection point for the ignition wire.
The bus is a 2007 Chevy Express Cutaway with a Thomas Minotour body.
Any tips appreciated!
Thanks
Old 12-06-2023, 06:04 PM   #2
Year: 2010
Chassis: Blue Bird (6-window Handy Bus)
Engine: Cummins 6.7l ISB
Rated Cap: 15 + 3WC
You donít really need an ignition wire tire in - all you need is some sort of switched positive input. I used a spare switch in the driverís control panel as an on/off switch for my Renogy 40A dc-dc charger. I can turn it on or off when the vehicle is running without worrying about it automatically coming on when the ignition switch is on (but bus might not be running)
desrtdog is offline   Reply With Quote
Old 12-06-2023, 06:24 PM   #3
I thought about that. I worry about forgetting and drawing the starter battery. I might go this way unless I can easily pinpoint the tie in
Old 12-06-2023, 06:56 PM   #4
Year: 2010
Rated Cap: 15 + 3WC
Understand. I should have been more specific - the switch on mine is wired such that with the bus off, no current will flow even if the switch of left on. Not sure how your panel is set up, but I had loads of extra spots in the main breaker panel so was easy for me.
Old 12-06-2023, 06:58 PM   #5
Iíll have to see if any of those switches is only hot at key-on. Iíd really prefer engine-on
Old 12-07-2023, 07:52 PM   #6
Year: 2010
Rated Cap: 15 + 3WC
Have you got a pic of the driver control panel (or whatever the switch panel is called)?
Old 12-08-2023, 11:18 AM   #7
Chassis: Ford E450
Engine: V10 Gas
I'm with you on this. I haven't installed mine yet, but when I do it will be with engine-on, it will have a switch near the driver (which I'll normally keep off), AND a small LED when switched on.
Reasoning is that I want control over the alternator load in case I'm in heavy traffic on a hot day.
Rucker is online now   Reply With Quote
Old 12-08-2023, 11:25 AM   #8
Good point. I guess Iím just going reclaim the wheelchair lift toggle
