does battery heat allow the packs to reach a higher SOC? or gives you more useable Watt hours if they are tempered?
The only thing battery heater does for the batteries is prevent the batteries from being damaged by being charged when they are at or below freezing.
We don't use low temperature cut off to prevent low temp charging, which will damage LFP batteries. Instead we just never let them get cold.
We placed the battery bank on a sheet of 2" XPS then laid a 45W underfloor heating pad. A 1/8" sheet of compressed hardboard, then batteries. We put 2" XPS around the batteries and left it open on the top.
The battery heater turns off if the underside of the bed reaches 80 degrees F. And turns back on at 50 degrees F.
During the warm months it is just off.
Also realize that the batteries themselves generate heat when they charge and discharge.
As for water under the bed, no room there. The battery bank is made up of 6 BYD 24V batteries that came from a commercial solar farm. Each battery is about 24" tall 21" wide and 9" deep. With the Insulation they occupy most of the space between the wheels.
