12-27-2021, 11:54 AM
Disconnecting Wires
Hello-
I’m getting started on making sense of and deleting unnecessary wires. I have a basic question to start. I can unplug these plastic wire connections correct? Do I need to worry about shorting something? Do I need to cap them off in any way? I am labeling everything and will trace back to panel. Just to start want to make sure I can start disconnecting without any precautions.
12-27-2021, 11:59 AM
Year: 86
Chassis: Ford B700
Engine: 8.2
make sure your battery is fully charged and the bus starts.
turn the bus off
disconect or cut a wire and make sure the bus starts and so on for everything you want gone.
once get into the light wiring i would use the same procedure with checking the lights you want to keep clip a wire you dont want and check your lights
12-27-2021, 12:03 PM
Originally Posted by wencington
Hello-
What “unnecessary” wires do you intend to delete?
I would offer a thought in a different direction.
Identify the wire, label it and ask yourself, can I use this wire for another purpose, maybe lighting for a closet or under a cabinet?
And yes, you can cut the wire flush, cap it wit a wire nut and electrical tape just to make sure the wire nut stays in place,
12-27-2021, 12:04 PM
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
If your plug's wired with anything other than a ground wire only (like that plug, which has one hot, one ground), then yes... if you disconnect the plug, leave it hanging, and the hot contact comes in contact with the grounded frame... it will short and (hopefully) blow the fuse for that circuit.
I habitually tape them over to prevent that unlikelihood. Or you could pull the fuse. Or you could just let it blow if it happens to ground so long as you don't care about anything else on that circuit. If it's something you're walling over permanently, I'd tape it up well. The last thing you want is some innaccessible short causing problems with a circuit you're using, plan to use, or may find use for later even if you can't imagine using it now.
Go away. 'Baitin.
Our Build: Mr. Beefy
12-27-2021, 06:41 PM
ok great. i'll make sure, just as an extra precaution, to tape over the ends of anything i disconnect.
as far as reusing wire... that photo for example is an interior dome light at rear of bus. i think i'd like to pull the old stuff and start fresh for anything...?
12-27-2021, 07:40 PM
WHY replace it ????
Because it looks ugly?
My bus (Amtran RE) had lights above the windows on both sides.
I am going to repurpose them, in the same place they are at. I am going with small round led lights, closet, extend the rear most so I can have lighting under the bed, also in any upper cabinets I install.
Others have saiid they would like to prevent hitting it with a screw or maybe it will rub against a sharp edge and create a short to ground.
Well that could happen with any wire within the bus body, underneath the chassis too!
The argument about hitting it with a screw, not a good one cause 1) there is already existing wiring, 2) you will be adding more wiring anyway.
Best thought I can share is A) find a way to re-purpose that already placed, fused and switched circuit or jus simply disable it at the feed by either pulling the fuse of disconnecting it from the switch.
I have even heard that it reduces weight in the bus….what, 5 pounds maybe?
I have read a lot of posts here of people who cut, remove wires and then ask for help because their bus won’t start or a circuit no longer works.
Best advice I can share, get a wiring schematic for your bus, study it real hard so you have a clearer picture of what it what and then make the right choices.
Me, I would cut and cap and leave in place.
Who knows, I might need that circuit further into the build!
Not trying to beat you up but I am not a fan of removing wires unnecessarily.
What kind of bus body you got?
I have wiring diagrams for IC Amtran that I would be happy to share.
Thomas bus body, just call a Thomas dealer. I have always been able to get a diagram from the dealers.
12-27-2021, 09:39 PM
got it. my goal was more of a strip to basics/clean up and start fresh. but i hear you and it might be nice to reuse if i can down the line. thanks for the suggestions!
i have a 2011 international
12-28-2021, 12:56 AM
Rated Cap: 31,800 pounds
I too have an AmTran RE (1996) that had interior lights (and speakers) above the windows on both sides. However, those circuits are COACH circuits and thus powered through the coach battery, original fuse blocks and switches, etc. Thus they but drains on the coach batteries which isn't good if the mission of the finished rig is to sit in place for days or weeks at a time. I removed the entire harness on the passenger side from the right rear corner forward. of the two remaining necessary circuits, one wasn't even in the harness past the rear wall molex connector. So the TS didn't even work.
On the drivers side, all unnecessary wires are being identified and pulled with the goal that only COACH circuits will remain in the original coach harness.
House circuits will all be powered from the house electrical system which will be new install.
Every rig and every demo is different but I've probably pulled well over 150 pounds of wire, cables, and control panels from my rig including:
155' of 7 wire cable
80' of 3 wire cable
200' plus of cables for the camera, left student, and other systems
30' of passenger side harness
3 large control panels for AC units
I should weigh just the electrical I've pulled.
OMG this is the biggest understatement. Know what you're doing before cutting wires. If you don't have skills with electrical systems go very slowly and one circuit at a time with restarts between each disconnect. If you're organized, disconnect (at connectors) and label several items and then restart.
And when you restart, ensure that ALL needed systems are functioning....... dash gauges, warning buzzers for air, and ELECTRONIC ENGINE CONTROLS like that throttle by wire "gas" pedal.
And if you don't know how to read schematics, try YouTube university, call a friend, take a class...... they are your friend.
So.... do you have a schematic for something close to a 1996 AmTran RE with a T444e????
12-28-2021, 06:59 AM
I uploaded a ton of electrical diagrams from the service manual I was gifted when I bought my bus.
https://www.skoolie.net/forums/f49/a...ams-25055.html
The master wire list identifies the wire by its number on the wire and separated by the colors groups too.
It should be the same on a ‘96 bus.
The service manual will not have engine info. Don’t know why! But i have a service manual and a diagnostic manual for the t44e. Pm your email and I’ll be happy to share.
You were on point with the house vs chassis distinction but that level of work imo requires some basic knowledge and understanding of the process.
My hat is off to those who have no knowledge and experience when they give it a try anyway. If anything, at least they are actively “ chasing the dream”.
Life is beautiful when you are lucky enough to be able to chase the dream!
12-28-2021, 08:47 AM
Chassis: CE300
Rated Cap: 23
[QUOTE=HamSkoolie;461479]
OMG this is the biggest understatement. Know what you're doing before cutting wires. If you don't have skills with electrical systems go very slowly and one circuit at a time with restarts between each disconnect. If you're organized, disconnect (at connectors) and label several items and then restart./QUOTE]
That's the irony. If you know what you're doing, you know that cutting wires that could be powering any number of circuits or systems you may not be immediately aware of is a bad, bad idea. Too many youtube vids out there of people doing this. Then it becomes a case of 'monkey see, monkey do'. I've been gone for a year from this forum. Come back on day 1 and I see (not this thread) another poster perplexed about cutting wires.
Where's Nancy Reagan when you need her?
Go away. 'Baitin.
12-28-2021, 08:59 AM
Welcome back.
Hope you put thousands of miles on that bus in the year you been gone!
12-28-2021, 09:08 AM
International is the chassis.
What body is on the chassis?
If your not sure, up above the driver head, on the front wall or above the entry door is a sticker.
that sticker will tell you what body you have.
Also, since you have an international, make contact with the parts department and give them the vin number. ask them if they could e-mail you a "Build Sheet". It is a doc that identifies every single part on your bus build.
Very useful information to have.
Then get a notebook and start printing, saving anything you find useful about your bus and build.
Here is the "Electrical Troubleshooting" guide that is included in the Amtran Re manual.
Great info for a beginner to start learning from!
Enjoy the journey !
12-28-2021, 09:39 AM
Chassis: CE300
Rated Cap: 23
Welcome back.
Thousands of miles on my joints, perhaps. But the bus isn't done yet
Go away. 'Baitin.
01-03-2022, 12:48 PM
Thank you kind sir. A wealth of information.
