Old 08-15-2020, 08:19 AM   #1
Coachwork: Blue Bird Intl
Engine: T4446
Dual Batteries, dead batteries, jump!?!
Ive just finished removing the rear heater coolant lines and cleaning up the mess from that, then starting the bus and running the heater system with seeming success. But then, a couple hours later, dead battery. or so it seems... I did have the electrical panel opened up a few times to disconnect the rear heater electrical wires, so maybe some problem there... but also, my dual battery system is a little confusing for me at the moment, and im not sure its hooked up properly.
sidenote: Previous owner bought the bus a brand new battery because she thought the one she had was not holding a charge. At the shop they checked the old battery and said it was good, so we took home both batteries. Have only had one connected so far. The bus ran great for the 4 hour trip home, and has been sitting for 2 weeks, no problems with the battery until now.
Last night, I setup the dual batteries to run in parallel and tried jumping from my GMC 3500, but after 45 minutes, i saw only a slight increase in power, not enough to get the brake pedal fully depressed for start, and definitely not enough for any cranking on the engine. Just a subtle "click" upon turning the key. i tried disconnecting the secondary battery, and just charging one, but had even less of a result. Now im wanting to revisit the battery setup entirely and make sure i have all connections proper.
Also, the only thing i did (intentionally) in the electrical panel, was to remove the rear heater wires. I did not remove the wires that run from the control panel/switches to the htr fuse panel, just the wires that ran from the fuse panel to the back of the bus. Would this cause a parasitic drain, or some other problem?
Here are some pictures of my battery connections ...
I read on Skoolie forums some conflicting points of view on jump starting... some say they've done it no problem even with small cars, some say NO NO NO , you must use a charger...
theHappinessBus is offline   Reply With Quote
Old 08-15-2020, 10:11 AM   #2
Willie_McCoy's Avatar
Year: 1980
Coachwork: Crown Coach
Engine: Detroit 671T
I am having trouble understanding exactly what is going on with your battery setup there.
You should have those looped wires (jumpers) going from + on battery 1 to + on battery 2, and - on battery 1 to - on battery 2. This is wiring them in parallel.
Like This:
Then the + on battery 1 goes out to the vehicle and the - on battery 2 goes to the chassis ground.
If you are replacing batteries you should always replace them all at the same time to keep them balanced, and this is also a good time to upgrade your cables if need be. This is what mine looked like:
You absolutely can jump start a dead battery on a bus, as long as both vehicles have 12V systems you will be fine. It will be very hard to start a big bus with a little car/truck but it can be done. I had to jump the Crown before I replaced the batteries and it took a full size van, a spare marine deep cycle, a charger/jump pak, and a lot of cables to get her going.
Supercoach Build Thread
Instagram
Willie_McCoy is offline   Reply With Quote
Old 08-15-2020, 12:31 PM   #3
kazetsukai's Avatar
Chassis: International RE
Engine: International T444e
Rated Cap: 76
Dead or almost dead batteries will be a huge time suck. Yes you can jump, but if your batteries have problems cranking replace them. We did recently, night and day difference. Starting takes a 1/4 of a second compared to 2+ seconds of the starter struggling before.
kazetsukai is offline   Reply With Quote
