Old 02-03-2025, 08:56 AM   #1
Electrician needed
I am looking to hire an electrician to totally rewire or help fix the wiring in my 1997 bluebird.
Hbarney is offline   Reply With Quote
Old 02-03-2025, 08:56 AM   #2
Old 02-03-2025, 09:37 AM   #3
ewo1's Avatar
WHY?
What's the problem...or should we just guess?
Old 02-03-2025, 07:27 PM   #4
Chassis: Ford E450
Engine: V10 Gas
Welcome. Are you looking for an automotive electrician or someone to fix wiring done as part of a conversion?
Old 02-04-2025, 09:27 PM   #5
Rated Cap: 37,400 lbs GVWR
Where are you? This is a big country. Is it problems with the original bus chassis wiring, conversion 12VDC wiring, conversion 120VAC wiring, or what? An electrician for one won't necessarily work on the other.
