Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-25-2021, 12:31 PM   #1
Coachwork: Ford / El Dorado
Chassis: E450
Engine: V10
Rated Cap: > 16,000 lbs.
Entrance Door outside switch key
Hi,
I have an '03 E450 w/El Dorado chassis. Former an elementary school bus. I'd like to locate a key for the entrance door, as the bus didn't come with the key at auction.
If you have a key, I'd gladly pay for a copy and shipping to southeast AZ, 85616
I believe most are keyed alike and will lock the post once I receive a key that works.
I have considered replacing the entire lock/switch assembly but can't locate one of those either, if you have an extra with key, I'd be interested in that too.
I considered taking the lock apart and having my locksmith build a key, but the lock does not disassemble.
Thanks for your help!
Xoloski is offline   Reply With Quote
Old 11-25-2021, 04:10 PM   #2
flattracker's Avatar
Engine: Cummins 350 big cam
Rated Cap: 86 passengers?
You could go to your local locksmith and they can make a key for the lock even if you don't have one. A locksmith can also come to your vehicle and produce a key if needed. With later model cars and trucks it can be complicated and expensive but this sounds like a simple lock. I have had this done before with success.
flattracker is offline   Reply With Quote
Old 11-26-2021, 12:28 PM   #3
Chassis: E450
Engine: V10
Already spoke with my local locksmith, because the lock is not able of being disassembled, he is unable to build a key or change tumblers.
Old 11-26-2021, 01:01 PM   #4
The locksmith that I used did not disassemble the locks. they found a key that fit the locks put it in and applied torque to the key, then used a file to cut down the key until all of the tumblers lined up and opened the lock. This has worked for a car and a bank bag, no problem. The bank bag was more difficult than the car so it cost more. I also got a second key made in each case.
door, el dorado, entrance, key, lock
