Originally Posted by chiggins
I looked into one of those, but then I saw this YouTube video, figured I'd go this route:
I'd just need to have a box and circuit breaker down line, I'm just not super entirely sure what I'd need, ya know? Definitely just DIY.
This is fine, but I would not use the PVC elbow- I'd use waterproof entry points for each cable:
https://www.amazon.com/Lantee-Plasti.../dp/B07B9VZYFJ
I'm not entirely sure I follow the wiring for the ground wire. Is it just screwed into the box using a ring connector? Is that the end of the ground there? Or another wire that's screwed in to the box, then screwed into the chassis? Or screwed into the box, and then from there into my inverter?
Screw into box, then go to inverter. The goal is to have the ground wire touch the metal of the box, and then pass it on to the main panel. This is an additional safety measure for ground fault equipment upstream in the shore source in case something in the box goes wrong.
I have a Victron Multiplus, and the AC in has three terminals, line neutral and ground.
Do you know what split phase power is? Sounds like your Multiplus takes 120V AC input. This box is for 240V AC- each "leg" is 120V, 90 degrees out of phase with one another. So when you combine either with neutral, you get 120V AC. When you combine each leg together, you get 240V AC. The breaker in the box pictured is a "double pole" breaker, designed to take both legs.
(Meters attached to each leg in my rig. Combined they show overall power consumption/distribution).
I don't know what your main AC panel looks like. Most residential panels are split phase. I learned this very early on in my research- thus I have a split phase inverter, so that I can use a normal, residential panel:
The double-width or "double pole" breakers are for 240V appliances (in my case, my mini split, my dryer plug). The single pole breakers are for 120V appliances, or your standard three prong outlets. My split phase inverter has three outputs- Leg1, Neutral, Leg2:
Well, your Victron Multiplus outputs 120V AC. It doesn't have a second "leg" for 240V service. So you can't wire a split phase, residential load center (breaker panel) with it the same way you do shore power- half of the positions on the load center correspond to Leg1, the other Half to Leg2. Also, the box you show, only one of those hot legs can actually go to the inverter, as from what you describe, it seems it only takes 120V AC.
I need to see what your main breaker panel looks like inside to go any further here.
it sounds like both AC and DC should be grounded to the frame? DC sounds easier to accomplish, I'd just have a wire going from one of my terminal bus bars into my chassis.
Yeah, nice clean, big cable from negative bus to chassis. And like I said, I did two-wire to the DC appliances.
On my Victron MultiPlus, my AC out terminals contain a ground, does that get wired into the chassis or elsewhere?
Sure, there's certainly no harm in it. Again, the ground is for safety equipment- if you have GFI outlets, and they sense their loads touching the chassis- do you want them to trip? If yes, ground the chassis. This applies to more than your chassis, by the way- what about your kitchen sink/faucet? This is why you see residential appliances (dryers, washers, fridges) internally run their ground connection to the chassis/body of the appliance- so a GFI upstream (if there is one) will trip if the surface of the appliance is electrified.
